I thought if I buy these ones there`s less chance that I`ll need to remove any other fittings in the light case to make them fit. Again, can I ask what your thoughts are here?
As there is no real reflector at the back of the light fittings I think the globes you listed would waste a lot of light to the back of the fitting.
Thanks Boots.
I`ve been having a good look on ebay and have spotted leds with the T10 fittings you mention. I like the look of these ones because they`re the same shape as the globes I need to remove. What do you think?
I bought a couple of the round ones to use in the light that is fitted to the handle next to the door.
That doesn't need to be too bright, more as a van locator for those late night staggers home......hehe.
Hey chartrock I have a 36 flat sitting loose in that spot, want to swap one of your round ones
I didn`t worry about ordering LEDs for the outside light. Going on Boots`s calculations 2 x 48LEDs [270ma each] will draw a charge of 540Mamps. The current outside light draws 830mamps. {Only one third of 1 amp difference per hour}.
Oh man, the outside light was the best change of all, its so much brighter now, it lights up the whole area. Everybody else we go with is jealous when we turn it on.
Hi Boots. I copied the above statement from another thread of yours. Can you tell me when you solder in parell, is that when you solder both negatives together and both positives together also?
Although the wires coming out of my external light were blue and brown, little bit of trial and error involved to work out pos. and neg. but same principle applies.Yep thats right... red to red and black to black
brown = active (12v) blue = neutral (-12v)
Generally!! but best to check with a multimeter, but I believe that those LED's just don't work when polarity is reversed not blow up.
