Yep, definitely still around.....bought one off them 2 weeks ago!Is Holiday annexes still around? Their website isn't working
Here is an alternative method of attaching the sail track. I sourced this track from a company in Qld, it allows the track to be mounted under the lid using stainless steel self tappers screwed into the aluminium angle, also used white sealer. The rubber seal doesn't push back on as far as before but it doesn't fall off. @hamish22 also did his this way and was happy with result!
View attachment 21522 View attachment 21524 View attachment 21523 View attachment 21525
Hahaha.....it actually needs a trim!OOOHH....
There is that perfect hedge again....
Gday BurnsyHere is an alternative method of attaching the sail track. I sourced this track from a company in Qld, it allows the track to be mounted under the lid using stainless steel self tappers screwed into the aluminium angle, also used white sealer. The rubber seal doesn't push back on as far as before but it doesn't fall off. @hamish22 also did his this way and was happy with result!
Hi mate, the company is called Fabtex and the track is called a concealed sail track, comes in a 7.5m length that they roll in about a 1m diameter to freight. Hope you get some rain soon!Gday Burnsy
I've been thinking of using Velcro as we don't get heavy rain like you do in the East! (In fact it feels like we don't get any rain in the West!!) But this track may be better. What was the name of the company for the sail track?
That's a much better method, I would copyright that. Top Marks!Here is an alternative method of attaching the sail track. I sourced this track from a company in Qld, it allows the track to be mounted under the lid using stainless steel self tappers screwed into the aluminium angle, also used white sealer. The rubber seal doesn't push back on as far as before but it doesn't fall off. @hamish22 also did his this way and was happy with result!
Can of worms....Anyone got a Kakadu annex? Just wondering if one is better than the other?
Yeah, like ford and holden! I'm sure @Ren1977 you'll get some replies!Can of worms....
