@Bluey the spare was mounted under the van between the 2 axles. I got a cruiser spare tire winder from the wreckers and made the cross member mounts and galvanised them, also made some spacer plates and screwed to the underside so the jack was under load when the tyre was pulled against it so the tyre would not come loose and rock around. Worked a treat and put the weight low down, over the axles and did not restrict clearance as the beam axles were still lower.
The Radio ariel was an areal bought for the Jayco shop, drilled through the cupboard above the sink and the cable run around the edge. the aerial run was an easy one.
