USA @bigcol here is the trip report.....
http://www.expandasdownunder.com/th...s-angeles-april-7-to-23-2015-no-expanda.6777/
I like those USB sockets, just never got around to fitting one yet......
what I have fitted is......
Ciggy socket in the glove box - wired to fuse box under glovebox - (for the Boss)
ciggy socket drivers footwell (GPS runs off that one) - wired to ignition
2 x ciggy sockets in back of center console - wired to fuse box under glovebox - (for back seat pass toys)
2 x ciggy sockets & 1 x Engel socket and switch in rear of cargo bay - wired to fuse box on cargo barrier (which also has power for the Amp & Subs)
the 2 fuse boxes are wired to the 2nd battery both with 100A auto resettable circuit breaker
fuse box in the front also has the DVD head rests wired to it
Hi @bigcol. Where did you source the fuse box from? Is 100A correct? Seems a high rating if its only for ciggy sockets. Is an Engel socket a higher rating that a ciggy socket? Or is it physically different?
One thing I have found with the Prado is that there is a shortage of outlets to charge all the gizmos that seem to go on holidays with us. There is only a 220VAC outlet in the cargo area. Hopefully it will run the Bushman fridge with no problems.
I have found that @bigcol is excellent to get advice and bounce ideas off.
