Electrical Where to connect aux 12v with the Drifter
3,039
3,413
Okay no spare points on the back of the drifter. My two options for the heater are either piggy back with another circuit or I am thinking of running a bit of 3mm auto of the lighting circuit to a relay. Then I can run circuits as I please off the battery ?
3,039
3,413
What brand of gas heater are you fitting Jim? Gas rather than diesel?
Bill
Sorry Bill missed your reply. Seems the forums alert system picks and chooses what it wants to alert you too!
Bought a truma same as you had. I really didn't want to go carrying another fuel source and with the cruiser I tend to stop at truck bowsers and I could envisage the headaches trying to fill a ten litre diesel tank with a 500litre pm truck bowser !
Billrw136
849
1,216
North Rothbury
No problem Jim!
3,039
3,413
I used a bit of jayco beige wiring and piggy backed it into one of the setecs lighting circuits so at a glance looks all factory. I even used the same translucent yellow spade connectors Jayco use on everything (and I mean everything) and fed the wire around the corner to the battery compartment and conected to a 12v auto relay. I will use this to switch a small fuse box and feed the heater.
But Iam not happy with the relay, the first one was a cheap Jaycar part and it got overly warm. I have swapped that out for another I had and it's better but there's a lot of temp in them and they will be on all the time! Wonder whether a Narva one at 5 times the price will be better or it's just 5 times the price cause it's Narva?
Does anybody know of any other quality relays avaiable? Somebody on fleabay is selling bags of 5 genuine Mazda ones!
@achjimmy I used one of these big suckers for my fridge relay so I could use current happy terminal lugs instead of the teensy weeny spade connectors .... I think you'd struggle to over heat this 200amp thumper
Reactions: skippy and achjimmy
