Hi folks,
just thought I would share a recent mod to our towing mirrors.
I have the Ora Big Reds, which initially I was happy with. But as time progressed I started to experience issues.
The support arm seems a solid solution to mirrors getting pushed in by wind. Over time the suction cup didn't hold as well and would on occasion lose suction and let go. The support arm was also not really strong enough, and once setting the mirror position up when leaving home, I would find at 100km/hr the mirror would slightly lift position so it would be viewing to high down the van.
The clincher was while driving on a recent trip at night, I heard a bit of a clunk and looked at the mirror to find to my surprise the support arm was gone......with no room to stop and being night time the chances of finding it was nil, so pushed on while pushing the folded mirror back out with every passing truck.
Got to the night time stop and decided the next morning to relocate the remaining passenger support to the drivers side. On inspecting the remaining clamps and noticed nearly all of the plastic clamp components had cracked. The cracks were the cause of the drivers side letting go and falling off.
Got home with the remaining support arm, that could also have parted ways with the mirror at anytime, and the boss pushing the passenger mirror back out from time to time.
So I got to thinking about methods of supporting the mirror that was more robust the the Ora support arms. The solution was parts made up from RAM Mounts (no association). It basically replicates the Ora support arm, but with metal (aluminium, cast aluminium) components and a much better suction cup. The components aren't cheap, bought online for around $130, so trialled on one mirror first and worked really well, so have now fitted off the second mirror.
The 2 universal joints make it very easy to fit. The suction cup is brilliant. the setup is much stronger now, over two recent trips not a single problem or letting go of the support. the extra strength has also stopped the mirror twist at speed, I can now set the mirror position at 0km/hr and know it will stay in that position at 100km/hr.
