Installed a switch panel for charging phones, tablets etc. It has 3 Lighter sockets and separate switches to turn the TV and stereo on and off. All switches illuminate when on so you can easily see if its switched on.
I found the 12v charging lead hanging out of my breakaway yesterday and thought about doing what youve done. Is the charger an optional accessory ... i certainly didnt get one. Is it just a 12v 1amp charger ?....Today I added a permanent charger for the break away unit to keep the battery fully charged.
View attachment 36518 View attachment 36519
I made a 2.1mm dc extension lead and connected it between the Break Away module and the plug in charger. Simple and I don't have to worry about the battery going flat.
Nick
15v for 12v battery ..... good on emDidn't get one with our van either @Crusty181 but recently got one online from RV Parts Express.... The original chargers are 15V 1Amp max!
I like the idea of a shower curtain and think I will go down this path.We use a shower screen in ours @Rockape which covers the door and toilet. Biggest issue we had was water running down the inside of the door and onto the floor when opened.
View attachment 36577 View attachment 36578
Thanks NickHi Crusty181,
Mine came with the charger. I will take a photo of the charger for you if you want.
Nick
Hi @dagree how do you go about installing a shower curtain? thanksWe use a shower screen in ours @Rockape which covers the door and toilet. Biggest issue we had was water running down the inside of the door and onto the floor when opened.
thx @dagree, job to get done b4 Christmas holsHey @Bonners The rail can be bought from a caravan supply store (Got ours from local Jayco Dealer) along with mounting clips, screws, end stops and curtain runners. The rail is easy to bend by hand and can be straightened if you muck it up..... Learnt that one by experience
No need to drill holes for the screws as the ceiling material is easy enough to screw straight into.
