Not having yet having purchased a battery to go in the tub of the BT before heading off to the high country last week I pinched the one out of the Expanda.
I just put it back in the Expanda and nothing now works on 12 volt unless plugged in. Everything is fine when on 240v but as soon as you switch off the 240v it should run on the 12v off the battery but it doesn't.
I drove the BT for 2.5 hours yesterday so it should be charged up and it ran the engle and led light no problem in the hc.
Yes I know I should check the battery voltage but my mate has my multi meter so I was hopping for a quick fix before getting it back. I have checked all the fuses both inline and on the setec.
The battery is only a 45aph and we have never had a problem running everything for upto 4 days while free camping but it is 7 years old Yes not the right way to test :fear: it but the test light works across it.
Could the battery voltage be to low to open the 12v circuit? If possible.
Thanks in advance...............:yo:
