Water inlet leaking
Kenty
41
11
Wanneroo WA
Hi all. Anyone have the continual dripping issue? I have researched this and found that people are changing their fitting over to Hoselink fittings. If so what have you done about the stop valve in the Jayco white fitting? Is the Jayco thread us fitting?
19,778
If you mean it's leaking at the fitting where you plug your hose in, mine has the normal hose fitting and it leaked until I replaced the O ring,. problem solved.
Hubble80
524
303
Moranbah, QLD
Personally I don't like how the hose goes into the van and then down through the floor on my model. I am looking at relocating it to underneath the van. I also want to put valves on the line to fill water tanks to save having to disconnect and muck about when wanting to fill the tanks.
My van is 3 days old, and we have 3 different water leaks.
The one of most concern is the one from the mains hose inlet. It has the Cost to Coast inlet with 2 tak fillers and the click on hose fitting in the centre.
After hooking it up for the first time on Saturday night, we found a puddle of water under the dinette table on Sunday.
I traced it back to water leaking underneath the lounge where the mains comes in and then disappears through the floor.
They use a step down threaded adaptor, and then a push on pressure fitting connecting to poly pipe.
After dismantling the whole thing and putting some more thread tape on, and tightening it all back up again (and having water spray all through the van on the first test), it seems to have fixed the leak.
Very disappointed that such as fundamental thing isn't tested under pressure before delivery.
mfexpanda
4,246
5,284
Brookfield, Vic
I would have thought the dealer you picked it up from would have a list to check and tick off before delivery
Glen Bundesen
336
212
Perth WA
The lack of clips in the John Guest fittings has been one of my major complaints with Jayco. Those black push on fittings (John Guest) are supposed to have a circlip where ever they are used/pushed on. My van had not a one!
19,778
Just started to fit those red clip locks on mine, bought a 90deg fitting for a plumbing mod and the fella told me about them, the fitting complete with 2 red clip locks was $8, so they aren't expensive. Will have to go back and get about 2 doz of them, just a cir clip to stop the collar from moving.
Yes one push and the hose was disconnected. Good tip about the clips, I've seen them before so will go out and grab some
3,031
3,401
Welcome to Jayco :p
Haven't had a leak (Yet) but will get under the van at some stage and check before our next trip in June!
Glen Bundesen
336
212
Perth WA
I have a 16.49.3 and used around 4 dozen. The hot water pipes also has these fittings. Also inside the van around the 12v water pump etc.
skippy
935
793
Butler/Perth WA
I too have tried diffent orings on the main conetion into the van and the connected is still leaking.
I am going to change it to match @Burnsy idea of a tap into the van as the main connector for the water inlet.:encouragement:
Reactions: Burnsy
Hi mate, the inlet that I put in is just a brass click fitting, the tap is an extra and is an outlet only.
any pictures on these red clips to hold hose in place. cheers
They are collet clips and are available at most places where the John Guest fittings are sold for about 90c each
Spoke too soon...... Found a few this afternoon so will be under the van when we get home and mark them. Going to try and get booked in for a few other warranty jobs so will add the leaks to the list!
Reactions: seanparky
I posted about this a while ago, just to be on Jayco's side for once, its not a requirement to fit the clips so they have done nothing wrong however it is a cheap upgrade if you want to fit the clips. I did them on my last van and will do them on this van. I actually spoke to someone at JG and he confirmed there is nothing to worry about if the clips are not fitted.
