I noticed in our Penguin that the sink appears to have been fitted by cutting out the hole, dropping it in, and tightening up the retaining clips under the sink. There appears to have been no attempt to seal the sink to avoid spillage getting under the sink and possibly damaging the benchtop.
I was hoping to get some guidance on what I should do.
First question, is it normal to for there to be no sealant or did I just get a sink put in on a Friday?
Should I be bothered doing something about it?
If so, has anyone sealed this area and if so how did you go about it?
My first thoughts were to take it out fill the area under the lip with waterproof sealant and put it back in.
But then I started thinking about getting it back out again. I became worried that the benchtop might not be that robust and it would stick to the sealant and separate from the underlying benchtop material.
So then I thought about applying some single sided foam strip and sticking it to the underside of the sink.
But then I thought: I can't be the first person on this forum to give this problem some thought.
Has anyone got any suggestions?
