After reading bigman's comment in another thread about his roof moving 20-30mm to awning side, I decided to check mine out - ours has moved about 10mm. I now have a reason as to why one of clamps (right hand side front) was harder to fit than the others.
Looking at how the roof works I came to the following conclusions - the struts that hold the roof up will do nothing to stop lateral movement - all that stops the roof moving to either side are the two "brackets for want of a better word" that are used to pop the roof. These are attached to the roof at each end by 16 screws (8 at each end) - similarly they are attached to the van by 8 screws at each end. The brackets are not made with great precision and it would appear that, in my van at any rate, they would allow a certain amount of lateral movement - the awning is the culprit I think, as someone else suggested.
If push came to shove the screws into the roof could be removed and the roof then shifted slightly back towards centre and then screwed back on in the new position.
I am able to raise the roof while in the garage - when in the up position I gave the roof a shove back to the opposite side of the awning - this seems to have centred the roof better than before - won't know for sure until I pull roof down (later).
Comments please - do others agree with the above??
Bill
Bill
