Any bright sparks out ther know how to drill a round hole without buying a 35mm bit?
Not undersized screws alone.................................................incorrectly used screws and glues!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!OUCH......
So it's not just Jayco that use undersized screws?????
You'd expect better for the $'s we pay!!!!!
ACDC helps with anger management in these instances!!!!!!!!!!!!!!!
:encouragement::encouragement::encouragement:I don't know (yet) about undersized but they sure do use the wrong ones. When screwing in to particle board or plywood why do they insist on using sheet metal screws? Could be worse I suppose after seeing staples used so widely on one van under construction that turned me off another brand.OUCH......
*Try posting a bit more so your post isn't boring*!!why doesn't the big green shed stock the same screw covers that van manufacturers use???
A dremil some small bit would make a nice cut in the soft wood in a van ?????use it to cut any shape once you have a mark to followAnd another on the road mod. 12v usb chargers beside the bed. His and hers. Gotta keep the peace.
View attachment 34469 View attachment 34470
