My BaseStation
Base23
464
1,082
Finally the solenoid arrived that I am using for the air tank drain. It is a 12v, 1/4" NPT threads, normally closed solenoid.
I fitted the switch and wiring all ready so all I had to do was fit the solenoid. I removed the manual drain from the tank and fitted a elbow 1/4 x 1/4 push to connect air fitting in the drain tank hole. I made a bracket to mount the solenoid to the floor of the van and then connected it to the air tank with some 1/4" tube.
Now to drain the water out the tank all I have to do is flick a switch.
12v solenoid with PTC fittings screwed and elbow for tank.
Small mounting bracket
Fitted to floor of van
Tank drain switch
4,296
Okay what's next??
I recon I saw 20+ base stations heading north last Friday, i think there was a motocross meeting somewhere near Bundy I had never seen so many at one time and that was all within 30K's !!
Reactions: Base23
3,031
3,401
Tank drain switch
Cool I had that same solenoid in my eBay was going to ask you if it’s suitable
Base23
464
1,082
Fitted another Andersen plug to the Basestation, I all ready had one fitted to the A frame but wanted one towards the rear of the van.2018-09-23 21.25.24.jpg
Base23
464
1,082
Have you re-plumbed the subfloor with PVC, or is that how it was delivered. Bit too neat for a Jayco
Yes is to neat for Jayco, When I first got the Van 3 years ago I spent about 3 week under the van tiding up underneath. Hoses and wiring was all over the place. Its a lot neater now, I added the centre PVC pipe to support the hoses going to the 3rd water tank.
19,474
So clean @Crusty181 will be jealous for sure, why do they still use 3 straps on the tanks when obviously 4 would be better...................actually both of you @Base23 and @achjimmy stop showing pics of under your vans, some of us have well worn under bodies and it makes us want to clean and polish stuff...............and we don't really want to.......
Base23
464
1,082
Took the Basestation away for the long weekend to pt Elliot. It towed great and was so easy to level when setting up.
No getting out the leveling blocks, sorting where to place them, getting told to go back, forward, back a bit more, no go forward and then unhook the car and its still not quite right.
Just push 2 buttons and its all done.
sits lower whilst parked
Difference in pressure from left to right.
underneath whilst parked
19,474
Sounds terrible, youv'e wrecked one of the great past times for some people in that you provide no entertainment by having a mild domestic and the getting in and out of the car to check all the time....................................Used to love the air bags on my truck,until there would be a leak in the line, get up in morning and she'd be listing to one side, drive me nuts searching for it........but it would be cool on Big Mal.
Base23
464
1,082
Fitted a new jockey wheel to the van today. I needed more travel on the jockey wheel and the factory alko wheel was becoming very hard to wind. I purchased the 5 rib Bos370 jockey wheel. It has 400mm of travel and can be operated by a cordless drill.
Fits in standard clamp and can be left in position while traveling
down with extention and base plate fitted
in travel position
6" dual wheels rared to 400kgs
even comes with protecting bag.
Reactions: achjimmy and Drover
