My BaseStation
Base23
465
1,084
Fitted the remote for the inverter and tested it all last night, All seems to work well. Transition between mains power and inverter power is seamless. All power points work through out the complete van and even the Ibis air conditioning works(battery power wont last long but it works)
Mains power plugged in and battery charging
Mains unplugged so Inverter power on
inverter running Air con fan only
Inverter running Air con cool mode
Base23
465
1,084
Inverter wiring to battery is now done, van is all back together as I had to pull a lot of covers, cupboards and front boot apart to run the remote control cable. Still waiting for the 250amp fuse to arrive but other than that its done.
Remote cable runs through over head cupboard then down wall in split cable cover to tunnel boot,
then across tunnel boot and behind club lounge to the pantry and connecting to inverter
inverter fuse holder fitted
Base23
465
1,084
While I was running the remote cable for the Inverter I thought I would fit a on/off switch for the Vast satellite receiver / PVR and the HDMI switch box as they were always in standby mode or on. The problems with them not turning off and staying in standby is that they are drawing about1.5amps all the time, The built in hard drive is always spinning making a slight hum noise, The unit was warm to touch and the display is lit up at night keeping my wife awake.
The PVR and HDMI switch box are plugged into a 12v cigarette / USB socket screwed to the wall behind it. All I did was fit the switch in the positive wire feeding the 12v cigarette / USB socket and drilled a hole in the timber panel to mount the switch so now I have control.
Rear of switch, Had to recess a hole for the switch nut as the thread was not long enough.
Switch fitted
Back together and now I can turn it off.
Base23
465
1,084
Did the 2016 table mod.
Worked out great, lots more leg room.
Had to remove the 8 screws that hold the top to the frame and the 6 screws that secure the adjusting handle. Then turn the table frame 90 degrees and line the top back up and screw it all back together.
Just a few holes in the base of the table from the original screws
Base23
465
1,084
How is that table going been thinking off changing our dinette leg to that one on our Starcraft. Jayco where not sure it work off centre although looks how it is on the Basestation the pole is on the outer edge?
Table leg is a great design, works well and easy to use. It dose flex just a little when leaning on the edge furtherest away from the leg.
Base23
465
1,084
thanks a lot of the pics mate.. really you think it be 4-6 bolts through floor.. 12 keep it stable I guess. Makes the job easier.
They put our bike rack on at dealer with 4 screws not the bolt through. It fell off almost. Just got the van back today and its through the wall now.
Looking at it just now and i am going to replace 6 of the screws with bolts and nuts.
Most of the table movement seems to be comming from the floor mount.
Base23
465
1,084
Fitted the 250amp anl fuse and tidied up the wiring at the battery. I removed two blue point joiners that Jayco use to join the fuse holders and soldered and heat shrunk them instead. Had a shorter negative cable made from the battery terminal to the shunt so that all sits better.
Fuse fitted
Still looks messy but trust me it is alot neater.
Reactions: davemc
Base23
465
1,084
Mounted a sphere TV Mount bracket to the underside of the top bunk to store the 40" LED TV that I use on the outside entertainment unit. So when traveling or when not using the TV outside I can store here.
I just drilled 2 holes through the base of the bed, made up a backing plate to spread some load and secured the bracket with 2 bolts and nylock nuts.
Still have to fit a strap as a safety backup.
Backing plate fitted.
Wall mount sphere tv bracket fitted.
TV on bracket.
This is a cover fitted to TV i made up for it
