Hi all,
has anyone had this issue with moisture in the LED side maker or brake lights with these lights (not sure on brand)? My van is a 14.44 OB Expanda 2017 model. Unfortunately it is out of warranty now so I can't have them replaced without handing over some coin.
Can I seperate the clear outside lens from the housing with a heat gun I wonder?
I was contemplating drilling a very small hole into the outside lens so that I can dry them out then placing a small bung in the hole to seal it up...until next time there is moisture ingress I'm guessing. I have attached some pics.
Cheers in advance!
Cheers in advance!
