17' Series Flush Tank - Leave it full or empty it?
Smergen
2,354
4,716
Bacchus Marsh
Just thought I'd put it to the learned forum, something I was wondering the other day...
When you get home, do you bother emptying the flush tank on your dunny (assuming you have one) or do you leave it with whatever the tank is in there?
Naturally I'm sure we all empty the cassette though don't we @Crusty181... ;)
3,060
2,345
I usually leave it full so its ready for next time
Casette dumped before leaving park usually then cleaned properly at home
Tanks also stored full then drained and refillled before next trip.
Reactions: Marv_mart
Turtle
Banned
Jan 23, 2011
359
308
Bathurst, NSW
I don't know why, but the flush tank seems to get algae in it pretty quickly and that's why I started emptying mine (back when I had one).
They have made it so easy to do, so why not? Saves the pump too, I would think.
3,060
2,345
Mine uses the water from the tanks I don't thick it has a flush tank
Yes the newer type toilets with the swivel bowl type arrangement do flush from the normal tanks, probably not a good arrangement as far as free camping goes as you'd go throught your water a lot quicker, but that's how they do most of them now. My mates van (not Jayco) it flushes from mains if connected or tanks if not.
Generally shouldn't get algae if kept full as much as possible, we never had any problem with ours in for years
I've also heard that the PINK flush tank chemical they supply can actually cause algae and problems within the tank, I've never used it, only ever fresh water.
Thanks @Turtle and @Bushman for the tips. Perhaps I'm missing something but what's the 'easy' way off emptying it @Turtle?
To drain the flush tank there is a sight glass just inside the cassette door that tells you the water level, just disconnect it from the top and let it hang down outside the door, also take the fill cap off to let air in.
Reactions: numbez
Smergen
2,354
4,716
Bacchus Marsh
Thanks @Bushman. We've only used fresh water as well and have just left it with whatever was left when we got home. Noticed the first flush when away a little discoloured but then no issue.
relgate
Superstar
2,946
1,902
Sydney, NSW
I had algae issues almost from day 1. I spoke to thetford rep at a show and she seemed aware of it. She also reckoned the new pink 'plus' is designed to alleviate this very problem. Cant test it now coz our new van flushes from the main tank!
Smergen
2,354
4,716
Bacchus Marsh
I'll keep an eye out for the "pink" stuff at Caravan show. In a way though, a minor algal bloom isn't really that much of an issue is it?? I mean, you flush the dunny with it, not drink/wash/clean in it...
I think the longevity of the pump might be more of a benefit. I know that even though they are waterproof they can eventually seep and suffer corrosion.
Reactions: Smergen
Hubble80
524
303
Moranbah, QLD
I empty mine and leave it open for a week to dry out properly, to save the algae growth. I usually flush with clean water to rinse the flush chemical out as well.
Reactions: Crusty181
coled1970
374
308
Hunter Valley, Newcastle
We leave as it is when we come home generally with some thing in it, we use nappie san in our flush and cassette and never had any issues with algae since we went away from the pink stuff. Sometimes we do add a bit of the rinse with the flush tank but always have nappie san in it to stop the algae growth.
