20,090
Bum ...................... I see a drip of water dropping from front of van lower trim to ground, close inspection shows its coming from a tiny hole in the rubber stone guard, its been on for probably 7 years or so and replaced the original vinyl blanket thing Coromal fitted, which a branch came up off the road decided to impail ed itself into the front of van via the stone guard vinyl, great for stones, not so trees.
I grabbed my Stanley Knife, hoping it would be a simple cut out and replace a section, not turning into a Daisy Chain, of course by the time I had followed the water I had opened up a track from one side to the other, as the water had worked its way across and down to escape, easily lifted in some places but others its sticking like the proverbial, might have to use a heat gun it to loosen the Quick Grip, experiment time again .............
So far it looks like it was confined to between the rubber and the van wall a bit more poking around to confirm and then I think I will spray it with Stone Chip Paint, no chance of water leaks and if it chips easy enough to touch up.................... Using Alloy Chekka plate too hard to fit and still can get water behind , paint is just so much easier should have done it last time... Toss up if to just use spray cans or get out the body paint gun, one is more expensive and one the chance of making a big bluddy mess is greater.....:D........
20,090
0600, notice freeezer is down to -4.2c , not good, check flu and pipes are warm but not burny, burny so fired it up on Gas and by the time I had finished my coffee, flu was Hot and so were the pipes .. Further checks showed the 240v element was throwing 249 ohms so my hope for a dud element was dashed as its within specs, couple of possibilities but they can wait till we get home when its nice and cold and I can do a good check of things and have my clamp to read what the power feed actually is ... Canberra is bluddy cold anyway.......
20,090
The Gods were smiling upon me, get home unload Big Mal and with fridge only running on Gas and the 240v heater element check inconclusive last week so before I start pulling things apart, I thought I will plug it into shore power for a good 12 hrs before I get out the tools, fridge being empty makes it a lot better ....................... At 1030 today I checked the fridge, freezer at -18c, fridge at 2c so either the last 1500kms shook something or the power at the park in Canberra had dropped off big time overnight and with a heater hanging off every power point in the park I wondered if poor supply but wasn't going to experiment with a full fridge as Gas was okay ........... Anyway all good now so a nice $$ saving .............. might just chuck my 240 line reader in bag next time, hate using my multi meter on mains stuff ......
425
I reckon a fair chance of voltage supply being well below 230v...given the number of people playing with electric cars and demanding Caravan parks allow them to plug in, plus as you note likely dozens of heaters going and air conditioners.
If you were toward the end of the supply line voltage would definitely not be the same as if you were at the head...could well have been the cause of the fridge playing up...
20,090
When I had the reading at the high end of the ohm scale with the element I was hoping that was the case and thinking back I did notice the ice cream was a bit soft on previous days but the temp was okay so I imagine it had dropped overnight, big reasonably new park with substantial power lines but when its 1c everyone has the heaters going full noise, being Canberra and 100% renewable no sun, no wind lol,lol ............... I'm just glad I don't have to pull things apart ...
20,090
Big Mals AC died end of last year :Cry:, my diagnosis was compressor stuffed and that has been confirmed not worth trying to repair these things I reckon and today was a big clean and maintenance inside the Van, lost a few kgs and near died from drowning in sweat ...................
Was pointed out we might want to go away later in year and AC would be needed so with that command/incentive/permission I ordered a Freshjet FJZ Pro so we will again have AC, bought it from CaravanRVCamping a mob I've used before in Brissie, very nice discount, free freight and saved a good $300 on other quotes and it was under 2K with discounts ................... Picked the right time as Specials are now on all over the place...:cool:
and the fridge still works ...................... :clap2::clap2:
855
I had a look at the specs since my coolman is over 10 years old. Looks good. Will you post a bit of a review of the swap and new features?
20,090
@jazzeddie1234 I will do that, I do like the option of being able to control the power use and that it would be possible to run it while off grid , my Ibis Mk III ran okay on the LRPS which is only 2kva and this one should actually run better as it has the ability to be able to adjust the power settings ...........
Just using my batteries and an invertor for off grid, isn't an option I would like as only 240ah Lithium and 560w of solar I would need to up it to minimum 400ah and 800w at least along with a new invertor of 2500/3000w plus a bit of rewiring so give that a miss, would want to be able to run it and have the panels cover the power use at same time so by late arvo when you would shut it down the batteries are still at full noise, have seen folk running their AC during the day, she's all good they reckoned but that night ran out of battery .... salesman wrong again...
