I have never seen it either. I have replaced the rear bar with a new bar that swings away from van if required for quick stop over. No porblems with the bar or the bikes.
I have replaced the rear bar with a new bar that swings away from van if required for quick stop over. No problems with the bar or the bikes.
Make the welds realllly good. I saw a 4 bike rack installed to the back of an Expanda via a tow ball sort of set up and when it hit a small bump in the road the articulation made it look like a whip.
Extra bracing if you can manage it and always secure the bikes to the rack so they can't swing around.
All the best
I can see this discussion is a bit old but I also had seen this mod previously and I bit the bullet and did it anyway.
Sure it was a butt clenching thing to drill through the fibre glass but it's all good. I have 3mm backing braces on the inside so any point load is spread and I also drilled through the reinforcing rib for extra security.
The missus drove behind me on one trip with all the kids bikes loaded up and said was solid as. I have done about 4000k without any worries. But not on corrigated roads - I would take them off for those stretches.
