Hi Bushman, to the tow vehicle, it is a 2011 patrol
Hi Benando did you get the airbags that go inside the spring or the ones that replace the bump stop beside the spring, if the one inside the spring I would strongly suggest getting the upgrade done on the top spring mounting plate. A friend of mine was towing his van with the airbags inside the spring and no upgrade done and the top plate failed and nearly pushed the spring up through the floor of his Patrol. The kit you buy to upgrade the top plate gets welded into position and strengthens the mounting plate. If you have the airbags beside the springs I don't think you will need them as the airbags take a lot of the load from the springs, this is what I have and haven't had a problem and I've done maybe 20,000 kms towing my Swan and now the Expanda. Hope this makes sense.Cheers everyone, airbags in, first test soon, I will let you know how they go
