Warning!!! Aluminium Box on a Standard Drawbar
Something to think about if you have a standard drawbar with an aluminium box mounted on it
Towed the van around the city this morning to get a few things done. Last stop had to perform a fairly sharp turn to get out of the parking area and heard a noise I didn't like :oops:
Always been conscious of the restricted clearance when reversing but didn't give it a thought going forward!!!!!
The end result......
And not a scratch on the ali box :noidea:
Reactions: skippy and bigcol
19,939
Turn the other way then you will have a match and no ne will notice........................been running the tape measure for my upgraded stone guard and had to change the plan as it came within the crunch zone, short draw bar no room for anything actually.
So is that a plastic bit that got crunched dags ??????
Reactions: blacky and dagree
3,039
3,413
Yikes tough one mate.
Currently away , but am going to check fuel useage tomorrow. But I had a substantial stone guard on the Expanda. This time on the Starcraft I went with a stonestomper. If intial consumption figures prove correct, the stomper will not take long to pay for itself !
AndrewC
207
233
Murrumba Downs, Brisbane
Get one of the hayman Reese tow bar shanks that has three hole locations for the tow bar pin. This allows the shank to come out about 80mm more and can make a massive differance. I did the same damage as you and the new shank made all my problems go away!
Actually use one of them but only on the second hole.... Might have to try it extended a bit more.
:thumb:
jandl
142
379
Bugger :( I have another longer tow bar shank but the chains don't reach so I have not used it. Better do something about the chains before I do the same thing. Thanks for the heads up.
Reactions: skippy and dagree
skippy
935
793
Butler/Perth WA
As long as no one got hurt that's the main thing.Don't worry @dagree I am sure your not the only one that has done this, Trust me I know :rofl:
I bet ya had a few scratches and rock chips anyway so I am assuming it's was due for a respray:thumb:
