Trailer plug wiring
Hi all, just went to change my socket on tug from 7 to 12 pin and found it has two more wires in the plug. They don't connect to any of the seven pins, they are the 2 very outside wires (purple and grey) light gauge and connect into terminals but I can only see a rubber type strip below the 7 pins in line with these terminals. Does anyone know about this and what they do? The 7 pin socket is a Lumen brand!
There is no voltage to these wires when car running or not. This plug was wired from dealer!
millers
282
246
Burnsy,
Does your Pajero have reversing sensors and do they turn off when you connect the caravan. If so these could be the wires that disconnect the reversing sensors so that you do not pick up the caravan when reversing. Just a thought.
Thanks for the replies, I have read some blogs from a pajero club and it looks like these wires are for the reversing sensor however it still beeps when you put in reverse with van on and plugged in, you have to manually turn it off on the dash so they don't seem to work anyway!
seanparky
203
100
Burnsy is that the original plug in your pic. If your changing that to a 12 pin plug make sure you get the one that has the normally closed reed switch.
Hi seanparky, yes it is the original 7 pin plug. I bought a Narva 12 pin but doesn't have the other terminals, is this for reversing sensor? please explain reed switch!
