Electrical Toilet pump not flushing
crackacoldie
2,597
3,806
Newcastle NSW
Hi all, have struck a problem with the pump for the loo not working. Have checked the fuse inside the toilet box and that is good. Any thoughts? I know I have read this problem somewhere but could not find the thread.
Cheers Cracka
Hubble80
524
303
Moranbah, QLD
I had a problem where my button locked on, perhaps your button has failed. Does it make a clicking sound when you push the button?
When you push the button does it "feel" right under your finger?
3,039
3,413
Yep the pumps seize. You can access it through the top button panel on the dunny. Peel the panel back and you can feed the pump out, helps if Your hands are like ETs. give it a spin and a squirt of wd40 and it might last another week or two. Get a replacement from England. About $35 or get raped here for $100 you have to cut the wires to install a new pump. Total don't be rude design.
mfexpanda
4,246
5,284
Brookfield, Vic
After reading this I realised I haven't even tried ours to see if it works .
Went and flushed ours 4 times and it works .
I hope you sort the problem out
Stone Stomper
388
336
Glenelg SA
www.stonestomper.com.au
Some pics below of removing the pump, WD40 worked for a while but kept stopping so replaced with a new one.
Christian
Wendy2537
How old is yours, I saw on this site that the Thetford loos have a 3 year guarantee, ours is now booked in at the local agent .. free of charge
richie/ karen
5
Yep found my pump sprayed it with WD 40 got another two trips out of it and it's seized again so bought new one $93 fitted today all good again I think it needs to be flushed more regularly when parked up! Can only 4yr old !
shiraz
140
154
sellicks hill s.a
Just had same problem, turned impellers with screwdriver worked with direct 12v put it together no go,turned out the 3amp fuse although
not broken was intermittent beeping when using a multimeter,replaced with a 10amp all good .now need to get 3amp to replace the 10amp. Its annoying when a friend drops in and finds the problem in minutes when you have spent 2hrs taking it to bits and putting it back.
now I can flush with confidence,
Shiraz
Yes it did follow all the above advice.
Reactions: ROnEM
