Could somebody please explain the workings of the Suburban Hot water system on our new Discovery
When operating on gas or electric and after it is switched on and the water is heated does it the then work off a thermostat. eg as hot water is used will it switch on and reheat or do I have to manually restart it.
I had it heating on gas OK then after it stopped I ran the hot tap a bit to see if it would re-ignite and cold water came back into the system but no luck.
Maybe I didnt run enough water off.
Terry
Terry
