16' Series Storm covers
coys 53
126
50
perth
Hi guys just thought I'd show you our latest attempt at erecting the storm covers as you hopefully can see we formed a frame from extension poles and it worked perfectly took 15mins/side to erect and not a tent peg in sight
2,652
3,819
We brought our covers from jayco geelong very thick mesh not like normal jayco ones they stay on all the time very good after 5 years never had an issue with any water or anything
coys 53
126
50
perth
1dayill
Yes the gas bottles can be accessed by lifting the privacy screen but only to turn them on or off or to select which bottle you are using. You cannot remove the bottle due to the bed being over them.
coys 53
126
50
perth
Sorry thought you meant the gas bottles the gazebo pods were bought from BCF as were the additional weights on top of the pods
coys 53
126
50
perth
That they are but given the time saved by using them they are worth it + when on a park minus the ability to drive a peg in they come into their own when packing up just empty the water out and voila no weight.
coys 53
126
50
perth
Having the cross member between both upright poles should negate the use of the centre pole if that is what you are referring to
coys 53
126
50
perth
Ours has the middle hole same as yours just don't use it, if its raining we lower one pole to allow it to drain off
