Sliding pantry conversion, as you know there is a bit of wasted space between the cooker and the wall on some of the expanders. there is a little work involved and took about 2 hours in total. parts required are from masters hardware kitchen area costing around $60, and edging black tape for the end panel, as this is the same removed panel from the kitchen, staples removed. a cardboard pull handle has also been fitted to try to make it look factory. There also is a internal panel that needs to be removed, which does nothing that i could see. slight modifcation to the top draw runner. i will send detail pictures of how to do this if there is interest. but pictured below is the final product.
