Just Browsing Reversing camera plugs
3,031
3,401
how do people connect there reverse cameras ?
I have the curly lead with dedicated plug but tbh it's a pain screwing it in each time? I have been thinking of using a spare couple of pins in the 12pin trailer plug. I know others do it like that and it's just one less connection which is always a bonus .
3,031
3,401
I have the "curly" lead as well (called a Wazza lead - why? I dont know)
I prefer its separate, but thats just me
Now you reminded me @bigcol yes it's a Wozza and no I don't know why either. Just that fine thread is getting on my tit . Iam putting a new bar on the Cruza and thinking can I simplfy this?
mine are push in type, not screw in - so mucho easier
(Polaris system ) 4 pin connectors
Also have the screw in plugs (Damned if I know where they got the name from????)... Haven't found them to be too much of an issue as yet! Originally they seemed to bind when screwing together but a bit of silicon spray helped that.
So that's why I had problems disconnecting it in December ;)
Have also heard of others connecting them via the 12 pin plugs and one I have seen was utilising 3 pin waterproof connectors.
Similar to these.
Tone
955
3,000
Warrnambool
I use 3 of the spare pins of the 12pin plug haven't had a problem with it yet. I did it that way because on less thing to plug in and it was there and didn't have to buy extra hardware for both my tow cars. Only prob if towed with a different car and wiring isn't the same could damage the camera.
I just use the small lead ends that came with the camera set. I have one ran up along the trailer lead gaffa taped to it to the end.
The last Auto Elec wanted us to put a wazza in when we got the D4 I said happy the small pins.
They slide in and you screw up the connector we do not go offroad and between 2 vans done a few k's.
I did say to him I was thinking of doing it on 12pin he was better to keep seperate.
Although when I said I was thinking of staying with the 7 in the Disco and getting a anderson he said better to stay all on the 12 pin :)
19,495
I had the cam working thru the 12 pin like @Tone, worked well, even let me know when the 12 pin had a melt down, cam died and found 12 pin melted from fridge connection.................now using a 7 pin, no pins for cam so went to Jaycar and got a 2 pin Mic socket and use that......
Reactions: dagree and bigcol
19,495
Full colour, 90 deg camera with the biggest screen, if you go for a rear mirror mount then go the one that replaces the whole mirror not just clips over, too heavy for the mounting.......
Most are the same chinese units with various labels, Safety Dave or Brash Imports are a good choice
Reactions: alexvk2 and bigcol
Mine also goes through the 12 pin. Needs a wiggle every now and then but otherwise works well
I forked out a small fortune 10 years ago for the Polaris system
2 4WDs
2 different Vans
still going strong
they are expensive, but damn good value in my opinion
I have one camera above the number plate on the Patrol, and one on the back bumper of the Van
7" screen next to the gear lever on the console, can have Camera A (car) or camera B (Van) running 24/7 whilst driving if I really want to
easy as
Macca_75
680
596
SE Suburbs, Vic.
Have you tried spreading the pin apart a little @Bellbirdweb ? Over time (from the wiggle to /plug/unplug the cable) the pins actually close up. Autoelec showed me - just insert a small screwdriver into the pin (they all have a split) and spread it apart slightly.
Ssil2000
121
187
i like the idea of using the 12pin plug for the camera... i wonder if you can then run the cable the car and have it discreetly positioned so i just plug the monitor in when i need it and there's no cables just hanging out of the dash?
probably a stupid question
No I haven't but am aware of that trick.
I never think if it until I get the fuzzy picture which is invariably as I'm reversing into a site, so a quick wiggle usually fixes it.
Will try to remember to check the pins.
No reason you couldn't do that.
Reactions: Ssil2000
19,495
Just hide the cable under the dash mat I suppose, usually only an RCA plug or similar, mine is the rear view mirror shows behind van or behind the ute.....
Always a good idea to regularly check the gap of the pins on 12 or 7 pin plugs, sort of like the points, if no gap poor connection and with a fridge power possible melt down.
