Exterior Replacing camec door flyscreen with midge mesh
Dingo193
144
120
On the road
Just wanted any advice on replacing door flyscreen with midge mesh. I went to remove door and noticed how many small screws
were next to big screws. I then stopped. Is there an easy way??
MDS69
728
794
Without going out to look at my van you wouldn't replace the mesh as the one fitted is part of your security door. There is a channel on the inside of the door where you can insert the plastic piping like a domestic fly screen and fit an extra layer of fine mesh on the inside of your door.
Dingo193
144
120
On the road
Ive done plenty of home screens ..i just wondered whether there was an easy way to remove screen on door in stead of doing it with door in situ.thnx
I did mine in situ, be mindful how much horizontal tension you apply. Dont make my mistake doing the same as I have done with house screens in the past. Too much tension and it easily bows the door
Reactions: bigcol and G Daddy
Dingo193
144
120
On the road
Thanks crusty..just was worried about getting the screen lines with the door etc..being particular.. any hints to make job easier? Thnx
I actually found it relatively easy fitting it vertical. Seemed like it should be easier to start with the sides to get that tension right without bending the door, and then top and bottom with virtually no tension just to take out the folds. Makes a huge difference with the little bugs, particularly the midges.
RickB
74
50
Vic
Can window screens be replaced seeing that the midgie mesh that I bought is finer than the window version?
Our van came with a white window mesh, which is now permanently stained northern dirt red. I replaced the lounge screen with a new one and thats the more traditional house screen grey. When I get some time Im going to have a shot at replacing the red stained kitchen mesh .... I'll post it up when I do.
RickB
74
50
Vic
When adding the midge mesh to the door normal fly screen rubber spline is too narrow and the mesh just comes out.
better to use GRUNT SHOCK CORD - 6mm x 5 m $8 from Bunnings.
RickB
74
50
Vic
I think I would still prefer to use the Shock Cord as the stretch may help to keep it in place over time.
‘Oh yes I forgot to thank Crusty for the tip!
19,475
Does midge mesh restrict the air flow as well as the bitey's ????................ Certainly need some after camping by the Isis.
RickB
74
50
Vic
So the next problem is the gap around the door.
So back to Bunnings and purchased 2 packs of below $3.47 each and installed around the door.
Boy what a difference, no gaps now.
RickB
74
50
Vic
Not sure I understand Crusty?
I didn’t remove anything to apply the foam tape.
It comes with a sticky back which I just pushed around the gap around the door.
19,475
The sticky left after removal just needs a wipe with some eucalypt oil if it doesn't come off with a bit of soapy water.
