Ranger XLT Standard Wiring
Wazza1962
Rosemeadow
Can someone let me know where the fuse is for the trailer plug.
I was wiring the the plug for a new caravan when i earthed out 1 of the wires and blew the fuse but don't know where it is located
Mick
165
201
I also have a 2015 XLT Ford ranger when I picked up the new van last year it is fitted with ESC.
I still had the standard 12 pin plug on the Ranger and was advised by Jayco to add a Anderson plug fitted for the ESC.
I have added the Anderson plug for the ESC.
now have also added another for the van fridge that is switched through a relay on ignition as leaving it in the standard 12 pin plug would drain the Ranger battery
I also at the same time put a fridge in the tub running on Anderson plug fused at both ends and using a smart DC TO DC charger as not turning of this option in the Ranger.
the only problem I still have is a weird one not even Ford can work it out.
I better start at the beginning with this
first picked up the Ranger on factory tyres
when i plugged in the van LED tail lights after 10 min on the road the tyre pressure sensor light would come on hit reset and 10 min latter on again.
no trailer all good.
Ford had for three days no ideas
Jayco no ideas
changed tyres to off road with original ford rim tyre sensors still no luck
found on the forum about adding resistors to van trailer plug this makes it last longer 20 - 30 mins before tyre sensor comes on
to this day still can not work out what to do????
