Here I'm printing up a holder for my very untidy socket set.
I can certainly relate to that but then lifting a wheel and shaking it isn't that bad unless it rattles..... then that leads to brakes......wheel bearings but somehow my brain is not keen on that job
These just arrived! $330 each delivered.
Exactly. My ute wiring is all 50a cable and breakers.I wouldn't worry about the 50 amp unless you are going to flog them down every day
4 weeks time! ishOh you really need to get away
@jazzeddie1234 , since when have you been worried about the expense of replacing a DC to DC charger???? And down-grading your solar charging system to a PWM type controller with all your electrical gear ?? Shame on you as a technical man!!!! You will miss the benefit of having a MPPT controller and its capacity to provide more charging ability, (especially in difficult conditions) even though you now have lithium batteries, by the end of your next journey.4 weeks time! ish
Battery box is in, juntek battery monitor running properly after a couple of hiccups, cranking battery trickle charger working... and the fridge is back in to test that before I start fitting all the other storage boxes.
In my trawl through all the wiring I discovered my projecta dc dc is faulty and the mppt part is not working as it should. It works fine when the altenator is feeding it and it's too expensive to replace so I've used a cheap pwm solar controller instead. Now I need to tidy and secure the cables.
Yeah, I know... It appears I ran most of the last trip with a faulty mppt in the tug. I compared it's output to the cheap pwm and will see a big improvement. The CV is all mppt and a replacement projecta is a bit down the list (and a different/ cheaper dc dc will create more headaches with all the compact cabling...)And down-grading your solar charging system to a PWM type controller with all your electrical gear
@jazzeddie1234 , it just goes to show that even with all the latest hi-tech gear, constant surveillance of all outputs and readouts is vital. More importantly still, is a complete understanding of normal expectations of equipment. Unless operating at full and proper potential, you are going to end up behind the 8-ball to some extent. Fortunately for you, you have the technical knowhow and ability to get around most predicaments that would be beyond the scope of most people. What a pain in the bum having to replace/re-route all that tidy cabling for a different DC to DC charger. Wires everywhere!!! Good luck and be careful. You do not want to release the fire and smoke demons! Just as well you have a complete wiring diagram for all the mods in your van.Yeah, I know... It appears I ran most of the last trip with a faulty mppt in the tug. I compared it's output to the cheap pwm and will see a big improvement. The CV is all mppt and a replacement projecta is a bit down the list (and a different/ cheaper dc dc will create more headaches with all the compact cabling...)
Will run the ute fridge for a few weeks and then decide
I say Eddie @jazzeddie1234 , you do have a few problems to say the least. Speaking about an earth wire on your MPPT controller had me thinking. My MPPT controller does NOT have any earth wire per se. It only has 2 terminals for solar input, 2 terminals for connection to battery (pos and neg), and 2 terminals for the loads. So, my "earth" must be the Negative to van battery as the controller is fixed to a wooden wall space, so no electrical metal connection between body of controller with screws. Me thinks you may have a loose wire connection or a high resistance leak of current across terminals. I would look further at that sort of problem, even opening up the back of controller to see what has started to get hot. I have had readings of over 23 amps (IN) through mine and up to 15 amps out on a few occasions without any signs of heat, and I have made extra space behind by using fibre spacers for more cooling. Remember, lithium batteries will accept all the power any input provides, and could cause an overload on input/output circuits.. Good luck!!!Well I've picked up a couple of problems during the pre departure testing. A bad earth on my mppt in the caravan made it do weird things and I picked it up by noticing the terminal was hot...
A few observations about those lithium batteries. They come half charged and I noticed they stopped accepting charge quite early (around 13.4 volts or so) so I suspect they are struggling to top balance. Anyway I left them sit for a day, then on charge, then sit, etc. They are very slowly coming up and now accepting charge up to around 14.4V
At dinner with friends my wife corners me with 'you never made that cloths line you promised'... so priority call to bunnings the very next day
While at bunnings I look for those sullage hose joiners - out of stock - so a spare minute and another 3d printer job produced these!
View attachment 6895970c instead of $5 works for me. All my hoses are 2.2m long to simplify storage in a chassis cross-member and I've been using old vacuum hose to link them together. Now I have a nice water tight joiner.
The new fridge compartment is a very different shape to the old fridge so I have to sort out some new shelf trays
