In preparation for the two week Tassie trip over Christmas/New Year, I decided to move one of the two 100AH Gel batteries closer to the primary battery so a to use storage space more efficiently.
The 2nd battery was located forward (towards the drawbar) under the opposite dinette seat. Moving a 35KG battery back towards the axle by a metre may not make any real difference to ball weight, but it certainly gives us back a large area under the seat that can now be used more efficiently.
In trying to remove the 2nd battery, it was very clear that Jayco's Quality Control team must have been out to lunch when the battery was installed. They have screwed the 2nd battery case down, put the battery in and then screwed the plywood seat base over the top, but this meant that the battery could not be removed unless you remove the entire plywood seat base, not just lifting it at the hinges. :mad2:
Battery & Battery Case installed before seat ply base installed :nono:
Battery now in place on the left hand side.
CTEK 250S Dual mounted on the side of the Setec cover box, with leads from Anderson Plug (Alternator) and pre-wired solar connected.
In addition to moving the battery and tidying up the cable loom and connections, I ran a 6B&S cable from one of the batteries to the front of the drawbar to a new Anderson Plug for connection to our new 200W folding solar panel with its own regulator. This gives us the option of parking under shade while still being able to put out a solar panel to recharge.
Hope everyone has a great Christmas & New Year.
Rohan
Rohan
