I've ordered it in our expanda just gives you a easy visual checkHi guys, ordered our first Jayco Expanda today. We didn't order it with a monitoring system and was wonder if it was worth while fitting one?
I have the drifter and all 3 water tank levels have started to read all over the place, I was thinking I should of just gone the simple coast to coast.
We have a Drifta and I love it, especially with Solar.
Shows voltage, current draw, battery state, estimated battery hours at current draw, charging or discharging, water tank level for up to 3 tanks, toilet tank level, inside temperature, controls battery and water pump and has a USB charger.
but does it do the dishes and make coffee.......................?????
mine must be the CtC one, just tells me how many Volts I have in the battery
As far as I know theres no calibration, all you can do is enable each tank, unless you have read different?Have you tried re calibrating it ?
