Chassis Lifting up on the tow ball
Axl
384
890
Brisbane/Bayside
Hi all another question has come to mind:), when I towed the van home it jumped/lifted up on the tow ball a couple of times, should I be concerned about this? The van was sitting a little hi at the front but I had 30psi in the airbags and the van was empty. Once I load a bit of gear in the front boot and I drop the pressure down a touch it should sit nice and level and I plan on using a hitch lock (as I do with my boat for trailer security) when towing so there is no way it can jump completely off the ball.
@axl Is it a standard towball style hitch?
If so there should be a threaded rod with a locknut on it. Undo the nut and screw the stud in a bit at a time and try lifting the aframe until it doesn't lift a lot. Just make sure you don't adjust it too much otherwise you won't be able to unhook it ;)
The extra weight and hitchlock (If the same as I have) will only reduce the chance of it dis-engaging!
Reactions: Axl
Hope it helps and works @axl
Another possible thing to check is the size of the towball..... Some older ones are imperial and are slightly smaller (Approx 48mm) than the 50mm ones of today.
Got caught out on that one years ago... Trailer didn't fall off but did bounce and rattle a lot
Reactions: skippy
Axl
384
890
Brisbane/Bayside
After googleing this issue I found that if the adjuster bolt is adjusted in to tight it can rub on the ball and snap off:o there have been a few cases of this happening on other forums. I think I will leave it as it is for now and see how it goes with some more weight in the front boot. It only bounced a couple of times in the 70klm drive home form purchase so with some more weight it may be fine.
skippy
935
793
Butler/Perth WA
I too had this problem on my old Pacemaker boat tralier and it ended up being the aduster bolt had worn away on the hitch on the boat tralier due to rust. Just tighten the bolt up on the hitch and all was nice and quite again just like it was when I first towed the old girl. If you're not sure though I would go and see a tralier specialist.
skippy
935
793
Butler/Perth WA
G'day @axl, @dagree is right. Just tweeke the adjusting screw in a little and lock it down with the lock nut. The early towballs were 2" as opposed to the new 'metric' at 50 mm and the difference may just allow a rattle in the fitting.
If I was you and it's the imperial tow ball I would replace it because there now elegal to use in WA not sure about Queenland though.
Reactions: Axl and dagree
Axl
384
890
Brisbane/Bayside
skippy
935
793
Butler/Perth WA
It shouldn't be the imperial ball as I only had the tow bar installed just recently as the Pajero didn't have one when I brought it, some interresting reading on this subject here http://caravanersforum.com/viewtopic.php?f=2&t=33011
That make for some good reading @axl
Maybe your right it's the bolt on the hitch that is not the right shape to match the tow ball. I would assume that it's been over tighten or damage in some other way and now it does not line up with the tow ball.
If it was me I would purchase a new hitch bolt and a new tow ball and see how is goes from there.
Quote of another forum >>>
This how I have adjusted the coupling ball adjusting bolt.
Both tow vehicle and trailer must be on level concrete with brakes not applied to trailer. Fit safety chain between vehicles.
With tow ball fitted to towbar tongue.
Lubricate tow ball with oil of choice.
Fit trailer coupling to tow ball.
Use large screwdriver to prevent adjusting bolt turning.
Undo lock nut on the coupling with a ring spanner, several turns.
Use large screwdriver to turn adjusting bolt clockwise until the adjusting bolt touches the tow ball.
Test to see if the coupling can be removed from the ball.
If the coupling can not be removed from the ball, turn adjusting bolt anticlockwise, using the large screwdriver, until the coupling can be removed from the tow ball.
Fine tune the adjusting bolt setting by turning it clockwise then anticlockwise one sixteenth of a turn, each trial, until the coupling can be placed on and removed from the tow ball without binding.
Note direction of slot on the top of the adjusting bolt.
Tighten lock nut on adjusting bolt using ring spanner, using screwdriver to ensure the adjusting bolt does not turn from chosen setting.
The adjusting bolt does not play any part in securing the ball in the coupling. It only serves to minimise the internal gap and reduce coupling noise. There is no problem in slackening it off a bit so that the coupling goes on and off easily - your van ain't gonna fall off! There are a number of couplings available with no adjusting bolt at all.
With a WDH fitted, you will have a much higher down force on the coupling in any case, which will eliminate any excess movement and rattling.
If you have a problem disconnecting your van, simply slacken the bolt off until it works more easily, it's not that crucial.
Axl
384
890
Brisbane/Bayside
Yep that is the process I will follow once I fly home form work on Tuesday:plane:.
There is a trailer building shop not far from me I have used them before for parts for my boat trailer brakes so I will also consult them on this issue as well.
Reactions: dagree and skippy
skippy
935
793
Butler/Perth WA
Ok ...don't forget to let us know how you get on.
19,506
Assuming the tow ball and hitch match, the adjuster is probably out by a smidge, it not only takes up the slack but also provides the wear point for the mounting otherwise you would wear out the cup on the hitch...........or more than likely the weight was at the back of rig and when you hit a wobbly bit the draw bar kicks a bit, happens a few times with my Treg hitch as it slides up the pin. My big trailer rattles and bangs when empty and it's just the slack adjuster needs a turn or two, but settles down when loaded up with sand.
