Thanks for posting.Not sure if this is already on the site, but I requested this from Bayswater Jayco.
Might be of use to others.
Regards BoD.
Can you please explain about needing an extra control relay? I need to get my car re-wired for 12 pin and I have an existing "hot wire" to pin 2 which is only active when the ignition is on.Thanks for posting.
Step 4 makes reference to a voltage sensing relay (I have a Redarc model already installed) however if you connect both the battery feed and fridge supply as they suggest, then surely the fridge would drain the caravan battery when connected to the car, but engine not running?
Others have suggested fitting a further control relay to the fridge to prevent this, but would have expected Jayco to at least warn about this?
We have 2 teenage girls. We're hoping the extra space and extra beds (so they can bring friends) will keep them camping for a little while yet. :mod: We have just sold a Goldstream camper and found we were getting tired of the set up effort, especially on touring holidays. :mmph:Great van. We had ours because of a teenage girl and boy.....they're over coming away with us, hence we are changing!
You've chosen well there! Enjoy.
We're looking forward to going camping without the effort of the Goldy. This will be our third "home". First we had a Camp/O/Matic hard floor camper, then the Goldy, now the Expanda. Each one a bit more comfortable and easier to set up. Unfortunately, each one a little less off-road capable than the one it replaced. But the girls are happy!Yep....we had an Eagle and needed separate beds for a teenage girl and boy.....then there was the set up, pack up, set up, pack up.....
