Cheers Boots
Nice setup mate. Very tidy wiring.
Only thing though is that there is a blocking (one-way) diode in the aux connection that you loose 0.6-0.7 Vdc across.
I have mine going direct to the batery so the voltage is as high for charging as possible.
Gil
Yeah that is how it came wired from jayco, yep i know about the diode http://www.expandasdownunder.com/showthread.php/178-Check-your-Anderson-Plug-wiring?p=2214#post2214 but we have had no problems with the battery so have not bothered to move the connection. As you correctly point out there is .6v to be gained from taking the diode out of circuit and for those seeking to maximize their charging while driving that is a good step Thanks Gil
