With the fly screens on my Bed End torn in multiple places the time had come to remove them for a trip to the canvas bloke..............
Here's a blow by blow How To...with piccies..............
Here's the tools needed...screw gun, leatherman or flat head screwdriver, trestles and tyre or something to hold the bed base up as you pull it off....
First up open up your bed end as normal and remove mattress, if you have tables and stuff under the bed then move them also.
Move outside and start to remove all the screws from the panel holding the canvas to the base......
It's handy to have a tray or tin to put the screws in........
Once all the screws are removed, gently pull the alloy panel strip off and then peel the canvas off and lift over the frame...................
........If you look at the frame near the hinge you will see a screw hidden away, remove this before you go inside van and put a horse or something to support the base............You don't really need to remove the base so you can skip this part and move to the canvas removal but I wanted to do some upgrading.
Back inside pull up the cover over the base hinge and start to remove the screws on the bottom hinge,
I removed every second one then did that again but you should find it has been stuck down so shouldn't move with the screws removed.....back outside with the canvas out of the way, undo the the shackle pins
and support the base on the tyre, then lift and push the base till it comes away and remove it................
Now you should have the canvas hanging from the frame, to remove just start at one end and pull it out from the channel section ,............
................. close the lid and your done......
The How To - Put It All Together will come later when I figure it out........................ next post is of some other things to do at the same time.
