Tool box all fitted up now with modified bottle brackets to mount the bottles. Pigtails were just to short when straightened and couldn't find anything locally but just found some 1m long ones on ebay which will be perfect so hopefully next week I should have the gas up and running.
@Stone Stomper Chris the plate arrived on Fri thanks again I will fit up tomorrow or next week sometime . Thanks again..
Maybe the go is to put a diesel jerry can (yellow) and put my unleaded in that
Then no one is the wiser
Will have to find a spot for diesel anyway, Most times I think the unleaded will go in the front box which means I need to add some vents as well
But most trips I won't be that far from fuel. But Warroora coral bay is the closest.
Have the new exhaust and snorkel on didn't make as much difference as I hoped, Definitely not like adding extractors. But there is a small difference for sure , The turbo sounds louder has a nice note to it but not any louder well I cant tell any difference. Seeing if it made any difference to the economy but car goes in on Mon for injectors to be done and service, hopefully its all good. Will be good to get a mechanics opinion that actually has the same car well two!
On another note I now cant get water from the front tap ? kitchen sink works ok will see if there is an air block in the valve and attach the mains to see if I can get flow that way?
