I've just returned from a weekend away off grid, and now when plugged into 240v any screw I brush past I'm getting a tingle off, also the frame under. I've done a search of the forum and could only find one issue from Kegs and I've PM'd him.
Prior to the trip away I installed a battery, having to remove the setec to get to the connectors as no wires were there. It was a last minute trip and the first off grid, so I also got a power inverter, which i had to run a grounding wire to (drilled hole through chassis). Both worked well over the weekend.
With the 240v off, and running off battery, no shocks, plug 240v in get shocks, remove battery and get shocks.....I've even taken the battery fuse from the setec....
Any assistance is appreciated
