I'm no expert but mine looks pretty much the same as yoursHappy if someone can advise. Not sure our drifter is wired up correctly? It seems to work okay. But see the pic below of the battery and shunt. They have the 2nd battery neg on the drifter side of the shunt, I would have thought it should have been just parreled to battery one? One of the other two wires is the solar in I presume, no idea what the other is should it be 12v from the tug? Presuming these stay drifter side of shunt ?
It's a total dogs breakfast and will be tidied up ASAP. I love how the state of the art drifter panel still uses a glass fuse !
I would say @bigman0510 will beat me too it @achjimmy
I am in wait a while country over here 3 hours behind the East Coast so I am assuming he will make it home before I do![]()
Yes got 2 batteries. Have no idea if it is working as it should but drifter seems OKHave you got two batteries Relgate?
Have you tried calibrating the drifter as to work out how much time/Amp's you have left in the battery Relgate?Yes got 2 batteries. Have no idea if it is working as it should but drifter seems OK
Apparently it does but I cant see how either.I get what you mean, there would be a little difference between battery to battery and both to the shunt. I wouldn't have thought it would make too much difference.
Can't see the difference either.... Only thing I can think of is maybe an issue with the equivalent of voltage drop due to cable size in a positive cable situation?
