Exterior Did the anode today
Ashevo
36
16
Karratha
My brother has just bought a 17-56-2 the same as ours. We changed his anode yesterday and can't get the 240v water heating to work? Fine on the gas. The van is 3 yrs old and the anode hadn't been changed. Have checked fuses and am now asking for any other suggestions?
cruza driver
Hercules
6,550
4,447
Mighty Victoria
Mmmm ok mate might be worth giving it a try I guess the switchs I don't think are that expensive.
Just remember to have everything switched off and isolated and if unsure ask the experts :)
If you do a forum search I know @chartrock has replaced one before.
Good Luck
Izzya123
112
42
Mount Martha, Victoria
Replaced mine last week. New anode bought from Jayco. Wouldnt wind in fully. Good clean, little plumbing lube, no good. Out about 5mm. It's in real tight with no leak so should be ok. Must be tapered end.
Freoboy
21
10
I did my Anode yesterday, only 12 months and it was almost all gone! I think I will go onto the changing every 6 month plan from now.
Reactions: skippy
skippy
935
793
Butler/Perth WA
Must be the local water quality ;)
Better check ours before we go away at the end of the month!!
We're at Coral bay at the moment and I won't be pluging the van into the local water otherwise the Artesian bore water will eat the anode within a week or two.:becky: Not much difference from the Butler water though @dagree :behindsofa: :rofl:
