Electrical Brake wiring
Lach
50
90
Hi all.
Done
some hard kms and put my head under van. See photo. Brake wiring on both rear wheel has ripped out. I can reconnect the wires but the ones from hub are same colour. Does it matter which way the are connected back together?
No, it doesn't matter which way they are connected. The electro magnets in the brake assembly are not sensitive to polarity.
That will be the easy part. You will need to put some thought into routing the cables and protecting them so it doesn't happen again.
Lach
50
90
Thanks mike
Yeah, just a bush fix today but needs a bit more thought. While van is back on bitumen today after a huge trip. She needs a lot of TLC...
Try to cable tie the wires around the axle as a temp measure to keep the strain off the wires going into the hub. If they break off you are up for a lot more work either rejoining the wires inside the hub or fitting new magnets. Either way it means removing the hub and repacking the bearings.
Lach
50
90
I added a 3inch length of wire so plenty of play....
804
The connectors on mine were smashed to bits so I bought new automotive type ones from jaycar, covered all the cables (which were just hanging down from the factory) with split tubing, and then used a dob of silicon to hold the connector up behind the axle, well out of trouble. Silicon is good because it will hold a cable but can be easily peeled off later.
