SOLD
ITEM DESCRIPTION:
Like new only a few months old, only pulled out to up grade to a higher output model
Click on the link for more info
The Genius is a revolutionary battery management system designed to offer a complete power solution for caravanning applications. Designed and manufactured in Australia, the slim and sturdy Genius is fully equipped to charge the current generation of deep cycle batteries.
To ensure that batteries are optimally charged and ready to use, the Genius has enhanced management capabilities such as boost charge, float charge, store charge and trickle charge modes. To ensure problem free charging, this device can also accept charge through an optional DC input.
The Genius has a range of battery protection features including reverse battery protection, battery current limit, over voltage protection, voltage current limit and fuse protection. The low voltage disconnect facility protects the battery against excessive draw. This device also hosts a thermally controlled fan to make sure that noise levels are kept to a minimum.
Key features:
ITEM DESCRIPTION:
Key features:
- Various charge modes
- Safe, flexible and reliable
- Battery protection features including – reverse, current limit, over voltage, voltage current limit and fuse protection
- Compatible with all lead acid type batteries
- Distribution board
- Auxiliary input
- Fault indicator
LOCATION (Geelong, Vic)
PRICE: $300ono
CONDITION: Excellent ,used condition
FREIGHT/DELIVERY (pick up or contact for postage cost):
CONTACT ( 0424884483 orPM):
