Hi All,
We have picked up our new 17.56-1 Expanda and took it for a test run on the long weekend. Everything went according to plan and so easy compared to the old eagle camper. We put the awning out and I attached the AFK and curved roof rafters no dramas at all and we decided not to put up the annex walls as they just slide along the sail track, no problems at all right? Wrong...we decided to put the longer wall up just to have a look and see what is looked like and I am glad we did. The bottom of the wall including the white strip at the bottom was completely up off the ground, so they have made the walls too short for the van. My question is, can anyone please confirm I have set the awning up correctly to put the walls on? ie. that I havent somehow raised the awning too high for the walls? When you want to attach the walls, the arm from the van across to the now upright (after removing from the van) post should be at a right angle? Just want to make sure I am covering all bases so Jayco don't try and tell me they are the correct length. Thanks
