So my replacement burner is working great which is a big relief but now I have an intermittent electrical issue - probably due to all the activity around the rear of the fridge.
Symptom: All lights flash after short drive on corrugations. Can only reset by unplugging the +12v permanent supply rail in the back. Otherwise fridge works just fine on gas /240/12 (when tug is not moving). I have wiggled /checked the supply cables - especially the 12 pin without triggering the fault. A read on UK websites suggest the front panel may be losing comms with the rear board so will check that next.
As an aside I found this really useful guide to enter service mode which I didn't know about. But the fault makes all the buttons unresponsive so I can't use that.
I learnt something useful from the guide anyway. I didn't realise the temp sensor in the fridge must be on a specific fin
