Starcraft 12 volt tv
Rockape
300
485
Hills District, NSW
As far as I know, The TV's that Jayco supply all run of 12v and come with a 240v power pack and 12 lighter adaptor. I only use the 12v adaptor and run it from a lighter socket. I remover the 240v plug pack from the caravan.
Nick
Yes. If it's a Sphere with the 12v adaptor then it's fine on 12v.
You should have been issued with a 240 and 12v lead.
We've only ever used ours on 12v, even when on 240, same as rockape.
They sell one as a complete unit.
It's a hatch type of installation ....with coax, 12v, TV bracket all enclosed and lockable. Tv just clips on bracket. They won't fit it on all models as it depends on space available.
The alternative is much simpler and cheaper. Just add a 12v socket to external wall with an extra coax point. You can also put a bracket there for the tv to slide into but that's just another possibility.
We got the above and it's simple and easy to use.
Best spot for that is under a fold down table so you can sit tv on that and easily hook up to 12 or 240 ...and use the booster that is fitted inside.
I just remembered I had this.
You could market these on eBay!
I can't remember what the Jayco price was for the hatch but this looks at least as good, if not better.
A talent in the solution dept.
Did I say I liked it?
