I'm doing the same....but it's taking longer as we're setting it up for the first time.
We'll always travel with full tanks for that very reason...if we stumble on a free camp site we need the water....with the extra Jerry can for water and the Costco slab.
and I've just set up,the back of the car and tossed out duplicate tools and the heavy fish filleting case (a present so I thought I'd better use it).....I just feed the fish anyway and all I need is a good knife in case I'm lucky.
Extra versa lights are also removed and I can't believe how many charging cables I've found.
Hey
@Drover we finally sorted out the problem with the Projecta 25 amp charger....poor stripping of sensor wires on installation. Narva Projecta guys have been great...couldn't recommend them enough. They've been in constant contact with photos, suggestions and lots of follow up. Batteries are now charging beautifully and it's peaceful,without the alarm going off. I almost miss it!
One thing I do need to sort out is the filling and balancing of the water tanks on the Golf. There's one filling inlet so that will need adjustment but we'll see how much of an issue it is before we change it...and add the Topargee monitor. If it's a pain that will be done sooner than later.
Jayco tanks setup is far better and their strange looking sullage fitting much more user friendly. The Golf has a screw cap over a much bigger sullage outlet and getting a reducer to fit the hose was interesting. Done now.
I'm not sure how we'll go with the full water tanks....195 litres ....bigger tanks....so if you don't hear from us, you'll know we're still clean with all that extra water! I didn't notice any issue with the full tanks when we picked up the van...it towed beautifully...but then we didn't have any of our usual crap in it.
:focus: Sorry again
@davemc
