Hi Folks,
Figured - I may as well start a vehicle thread since I tend to get up to a few things that people may like...
Pics below are actually a tad old as I have since changed wheels so I'll post some new ones up tonight
List of Mods so far:
DIY Dual Battery Setup - 80AH All Rounder under Bonnet
Pirhana DBM180s
ARB Large Air Compressor under Bonnet
A few Tatt's to break up the white a little
Kaymar spare wheel extension Bracket
BFG AT 275\65\17's
Pro-Comp 7005 Series Cast Black Alloys
P3 Brake Controller
GME UHF
Hella and Cigar Sockets in the cargo bay
Dual Battery Monitor in the cargo bay
Wrapped interior trim with Carbon Vinyl to pretect from scuffing.
DIY Rear Mud Flaps
DIY Rear Work Light
Two Baby Seats on the Middle Row
Here are a few Pic's
Enjoy
Aux Battery:
12v Sockets in Cargo Bay
Dual Battery Monitor in Cargo Bay
Tatt's
Scuff Protection
GME Location
P3 and ARB Compressor Switch Location
Finally got round to Doing a little Mod I've been dying to get into...
Modification so that I can Manually switch on the camera when ever I want and also switch between a few cameras on the single display (rear, Caravan, Front)
I have installed two mini two way switch's just below the screen, The one on the left is setup so that when over to the left the camera operates as per normal and only comes on when the reverse gear is selected, but when flipped over then it switches the camera on no matter what gear is selected.
The other switch is not funtioning yet but I will be wireing it up so that I can select to view one of two camera's - Rear for now and when fipped it will show the van or front camera (if i decide to fit one) but probably just either Rear of car or Van.
Pretty easy mod to all of about 20 Mins
Centre piece removed ready for holes to be drilled - how people you know drilling into the center console of 150 Prado's
Holes Drilled - One switch in to check fitting
All done and switchs fitted - decided to remove the red covers
Only the one switch wired up for now - The other one will be done when i get another camera
Switch in standard position - No camera as car is in Park
Note the switch is now flipped and camera is now on and car is still in park
Anyone one want further details feel free to ask - Cheers
Pirhana DBM180s
BFG AT 275\65\17's
P3 Brake Controller
GME UHF
DIY Rear Mud Flaps
DIY Rear Work Light
Enjoy
Aux Battery:
Tatt's
Scuff Protection
GME Location
