My neighbour makes office furniture and did it on his panel saw. Does finish it nicely.Wow nice cuts! What did you rip it with?
can you still get a bed converter for a trifold table ?looking good.. nicely cut.. did you find some laminate somewhere to match?
If I can talk Sarah around to the trifold I probably have to buy some off Jayco.
Yep that's right mate.@17triton is that one of those saws with a blade top and bottom?
Still thinking about this one Jim, I might knock up a trial cupboard out of ply and either laminate it or make a new one out of lamipanel or similar.What are you doing for the cupboard against the wall?
Yes I have some edging which is nearly identical so will look good I think.looking good.. nicely cut.. did you find some laminate somewhere to match?
Was done in the 17.58 thread Sarah thinks the kids hit the chair leg and table. I think I am loosing the battle so may just make a thinner table that fits between seats.can you still get a bed converter for a trifold table ?
Latte Matte is the colour. Ok something to think about with the cupboard thx.Matt was is your laminate colour?
That Jayco Cupboard wasn't badly priced iirc for what it was just I can't now find the flaming quote:-(
View attachment 39532 View attachment 39533 View attachment 39534
Posted on my thread but thought it would be good here. I started on my trifold table today cutting up the original and making it a little narrower. You can see the foam sandwiched between the ply. I am going to dig out some foam and glue in some hardwood for the hinge screws to bight into. I need to router some curves and re edge it all then.
I'm waiting for it to come back from getting edged so will measure then but it's about 50-60 mm I think. I want to keep the top ones back the blind cover on the wall.Hey mate what was your breakup of the measurements? The bottom piece was longer by looks around 100mm this obviously needs to be longer but does it need to be that?
The panel against the wall is 260mm, middle one 210 and the large section is 500mm. The table is now 600mm cut down from 730mm.Hey mate what was your breakup of the measurements? The bottom piece was longer by looks around 100mm this obviously needs to be longer but does it need to be that?
Bunnings for $14 a bargain.Great stuff mate. Where'd you get the leg from .
