Hi all, Just a quick post for those putting in a Redarc battery isolator in their New Jeep Grand Cherokee - beware !
Having just bought our new 20.63.1 OB I had a Redarc battery isolator fitted to the jeep by a reputable auto electrician recommended by the Jayco dealer. The intention was for the isolator to disconnect the van from the battery when the volts fall below 12.7 volts (so when the motor is off) and reconnect the van to the battery when the volts go above 13.2 volts (when the car is running) - pretty standard stuff really. BUT....Jeeps don't play by the same rules as most other cars and the smarts in the jeep doesn't necessarily pump 13.2 volts to the battery when running - it varies the charging volts depending upon what is required.
SO...when we picked up the van the jeep felt that it would charge over 13.2 volts so all was well - the ESC light indicated it was OK, the fridge automatically switched to 12 volt supply - all was nirvana. BUT...the next time we went to tow - no esc/no fridge. So after some research - found out about the Jeeps battery charging "smarts" and disconnected the ESC from the Redarc and went straight to the battery. Not too worried about the fridge at this stage - but its pot luck if the Redarc will activate. You can override the Redarc using an override switch - which is on the cards for me.
SO... if you have a van with ESC, and tow with a Jeep Grand Cherokee, and have a Redarc battery isolator fitted, and your ESC is on the switched side of the Redarc......chances are you wont have the ESC when you need it, and your ice cream will have melted !
Happy for someone with more grey matter to correct me on any of the above as its always fun to learn !
