With the Velcro around the vents, do you recommend putting the Velcro around the edge of the vent (on the plastic) or on the van wall (the fiberglass around the vent)?
I stuck it to the van itself, vents that are low and have the C/plate aorund them as per the OB's are a little harder, i struggled to get the stuff to stick so perhaps for them on the actual vent?With the Velcro around the vents, do you recommend putting the Velcro around the edge of the vent (on the plastic) or on the van wall (the fiberglass around the vent)?
I had that thought myself, i will be interested to see how that goes, let me know!Im about to make a "positive pressure" system for our Discovery using a Hilux air filter box and vehicle fan blower. Air will be sucked in through the filter by the fan and blown into the van to pressure it and hopefully keeping dust out. Well thats my plan anyway.
A feature you might want is a remote control or wired switch to activate and deactivate the positive pressure system.
When you are the only one on the road, then activate it and have a vent seal open and fans running, however, if there is someone coming the other way or in front of you kicking up dust, deactivate fans and seal the vent.
Rohan's Idea (patent pending)! I am sure there is a buck to be made here![]()
[ ATTACH=CONFIG]10702[/ATTACH]
a scupper vent works wonders on the roof, great on a car canopy as well
and a trick i use for testing seals is to smear a bit of grease on the seal then close the hatch gently and latch it, when you open it the grease smear shows how well the seal is working. of course then you have to clean the grease off
we replace most leaking seals with a double lip seal, that usually fixes the bugger
