Feb 23, 2026
It's still in my mind to set up house for the genny but in near 10 years ran the genny twice once for about 3 or 4 hours after big...
Feb 23, 2026
@Drover , I always had an idea that the "Pro star" and "Morning Star" regulators were suitable for use with "house" panels as a lot of...
Feb 22, 2026
I could do the thing myself, it isn't difficult, and oddly enough there are even some You Tube videos around explaining how to hard wire...
Feb 21, 2026
Yep...the normal RCD won't work as it should with an Inverter on board as there is no external earth for the RCD to direct any current...
Feb 21, 2026
I imagine the sparky will love that as they seem to shudder at the thought of fitting a genny socket on house boards.. The...
Feb 21, 2026
Have now fitted the 2000w inverter, fused via a 250A fuse direct to the battery leads at the Busbar connection being the Busbars are...
Feb 20, 2026
Thats why I prefer parrellel on van, short runs so no need for extra volts, I'll take the Amps .............................. Using...
Feb 20, 2026
Good to hear your new tug is meeting expectations...8-)
Feb 20, 2026
Feb 20, 2026
Feb 19, 2026
It's all about WATTS Ian. 5.4 amps at 36 volts amounts to approx 194 watts, while 5.4 amps at 18 volts amounts to only half the total...
Feb 19, 2026
Another Dunny Idea ...............
Some camps weve been at nearest dunny could be 50 miles or more away and then some you don't want to get out of the car let alone walk...
Feb 18, 2026
Not a real bad idea if you spend a lot of time off grid where there are no Dump points...for the girls anyway...quite a few vanner's are...
Feb 18, 2026
The only problem twos are the ones that refuse to exit after multiple flushes and a queue of dumpsters cheering on :oops:
Feb 18, 2026
